FS Bisesik output trafo fully mounted used on AK 4493 dac --- it is V out Trafo
price 140 euro
Best Bjarne
price 140 euro
Best Bjarne
it will not give the right impedance there are resistor on the board it is the samme trafo as this vout
https://www.diyaudio.com/community/threads/output-transformers-for-dacs.327794/ post 8
hope this help trafo is 1;1
thanks for interest,, just now i use it again,, maybe later
i have for 14days ago get a new amp and it is very good together with the trafo
Hi Bjarne, just a short message to hear if you are still using your DAC transformer?
English please.
dave
diyAudio moderation team
Hi
yes i still use the Dac Transformer Have not found a better output for my AK4493 Dac
Best Bjarne
Best Bjarne
On should never measure signal transformers with a DMM.......Can you measure input/output impedance of the coils with an ohmmeter?
Need to know the ratio...
Why?
