Selling my pair of Bisesik current DAC output transformers.
winding ratio is 1:4.
There are a couple small dings on the outer metal casing.
Sold
Sold
These are sold now but can do BAL or SE > BAL or SE.I assume theses are SE>SE
primary centre taps are only needed for a few DACs with offset on the output, TDA1541 for example.
You can still drive a balanced input without a secondary centre tap I've found, I still don't know what the advantage of the centre tap is for getting a balanced output but would be interested to know.
