FS: Beyma CP21F Tweeters
Excellent high efficiency slot tweeters. I prefer these over the JBL 2405 Alnico slot tweeters, Fane horn tweeters, EV 35, EV 350 alnicos, and Fostex Alnico horn tweeters. Wide dispersion and very detailed and sweet. Very low distortion and super efficient. They are in great condition. $150.00 for the pair plus shippimg from Ohio. Email me at magnetar@joimail.com if interested. Thanks
Impedance 8 ohms
Minimum Impedance 8 ohms @ 9.0 khz
D.C. Resistance 6.1 ohms
AES Power Rating 25 Watts
Program Power 50 Watts
Sensitivity (1W/1m) 105dB 1w @ 1m
Frequency Response 3.5kHz - 20kHz
Recommended Crossover 5.0 kHz or higher
Dispersion (H x V) 140° X 40°
Voice Coil Diameter 1.5" / 37.6mm
Magnetic Assembly Weight 2.64 lb. / 1.2 kg.
Flux Density 1.55T
BL Factor 5.2
DATA SHEET
