• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
FS: Audio valves, vacuum tubes EL34, ECC83, EL84, ECC802S, etc Telefunken, Tesla
Hi mates!
I have some tubes for selling here.
Here go the list:
1. NOS Tesla EL34 6CA7 brown base - welded plates, double "OO" getter. = 8pcs., 75 USD each
2. NOS-NIB Telefunken ECC802S - diamond bottom, same data codes. THE BEST ECC82 type. Made in West Germany, Ulm factory = 6pcs., 250 USD each
3. NOS Tungsram EL84 6BQ5 smoked glas - PERFECTLY MATCHED PAIR at Ia=50mA and S=15mA/V = 55 USD for both (pair)
4. NOS Tungsram ECC82 12AU7 - Low-noise = 10pcs., 13 USD each
5. NOS Ei ECC83 12AX7 smooth long plates *Telefunken copy* - made on Telefunken tooling in former Yugoslavia - 1pcs. at 30 USD
I can provide pictures on request.
Shipping via registered priority airmail with tracking number - starting from 16 USD.
PayPal and Moneybookers as a payment methods.
For contact, please personal massage or mail at: "audio_tubes(at)yahoo(dot)com"
HERE IS UPDATED LIST:
2. NOS Tesla EL34 6CA7 brown base - welded plates, single "O" getter. = 3pcs., 70 USD each
3. NOS RFT EL34 6CA7 - Germany stapled plates, single "O" getter. = 16pcs., 45 USD each
4. NOS-NIB Telefunken ECC802S - diamond bottom, same codes. The best ECC82/12AU7 type. Made in Germany at Ulm = 6pcs., 250 USD each original
5. NOS Tungsram EL84 6BQ5 smoked glas - PERFECTLY MATCHED PAIR at Ia=50mA and S=15mA/V = 55 USD for both (pair)
6. NOS Tungsram ECC82 12AU7 - Low-noise = 10pcs., 13 USD each
7. NOS Ei ECC83 12AX7 smooth long plates *Telefunken copy* - made on Telefunken tooling in former Yugoslavia - 1pcs. at 30 USD
8. NOS RFT ECC83 12AX7 - made in Germany. Good price/performance - 5pcs. at 22 USD each
9. Slightly used RFT EL34 6CA7 -ALL TEST VERY GOOD Germany stapled plates, single "O" getter. = 3pcs., 32 USD each
Shipping via registered priority airmail with tracking number - starting from 16 USD., without tracking number - 7.5 USD, but I can't be responsible if parcel lost - your choice.
For contact, please personal massage or mail at: "pen1.bg@abv.bg"
Update:
3. NOS RFT EL34 6CA7 - Germany stapled plates, single "O" getter. = 2pcs., 45 USD each
5. NOS-NIB Telefunken ECC801S - diamond bottom, same codes. The best ECC81/12AT7 type. Made in Germany at Ulm = 8pcs., original 150 USD each
6. NOS Tungsram EL84 6BQ5 smoked glas - PERFECTLY MATCHED PAIR at Ia=50mA and S=15mA/V = 55 USD for both (pair)
7. NOS Tungsram ECC82 12AU7 - Low-noise = 8pcs., 13 USD each
8. NOS Ei ECC83 12AX7 smooth long plates *Telefunken copy* - made on Telefunken tooling in former Yugoslavia - 1pcs. at 30 USD
9. NOS Siemens E88CC CCa 6922 - gold pins and data code of the producing factory in Germany! Double stage "O" getter and chrome shield between the plates = 8pcs., 126 USD each
10. Slightly used RFT EL34 6CA7 -ALL TEST VERY GOOD Germany stapled plates, single "O" getter. = 3pcs., 32 USD each
Update:
1. NOS Tesla EL34 6CA7 brown base - welded plates, double "OO" getter. = 8pcs., 70 USD each
2. NOS Tesla EL34 6CA7 brown base - welded plates, single "O" getter. = 3pcs., 68 USD each
3. NOS-NIB Telefunken ECC802S - diamond bottom, same codes. The best ECC82/12AU7 type. Made in Germany at Ulm = 6pcs., 248 USD each original
4. NOS-NIB Telefunken ECC801S - diamond bottom, same codes. The best ECC81/12AT7 type. Made in Germany at Ulm = 8pcs., original 148 USD each
5. NOS Tungsram EL84 6BQ5 smoked glas - PERFECTLY MATCHED PAIR at Ia=50mA and S=15mA/V = 52 USD for both (pair)
6. NOS Tungsram ECC82 12AU7 - Low-noise = 8pcs., 12.50 USD each
7. NOS Siemens E88CC CCa 6922 - gold pins and data code of the producing factory in Germany! Double stage "O" getter and chrome shield between the plates = 8pcs., 126 USD each
8. Slightly used RFT EL34 6CA7 -ALL TEST VERY GOOD Germany stapled plates, single "O" getter. = 3pcs., 30 USD each
Shipping via registered priority airmail with tracking number - starting from 16 USD and depend on the weigh., without tracking number - 7.5 USD, but I can't be responsible if parcel lost, stolen or damaged - your choice.
Update:
2. NOS Tesla EL34 6CA7 brown base - welded plates, single "O" getter. = 4pcs., 68 USD each
3. NOS-NIB Telefunken ECC802S - diamond bottom, same codes. The best ECC82/12AU7 type. Made in Germany at Ulm = 2pcs., 248 USD each original
5. NOS Tungsram ECC82 12AU7 - Low-noise = 8pcs., 12.50 USD each
6. NOS Siemens E88CC CCa 6922 - gold pins and data code of the producing factory in Germany! Double stage "O" getter and chrome shield between the plates = 8pcs., 126 USD each
7. RFT EL34 6CA7 -ALL TEST VERY GOOD Germany stapled plates, single "O" getter. = 1pcs., 30 USD TEST: Ia=74mA; Ig2=11.5mA; S=11.1mA/V
8. NOS Tesla ECC88 6DJ8 - NOT "JJ" old yellow label production = 1pcs., 14 USD
9. NOS RFT ECC81 12AT7 - Single "O" getter = 30pcs., 11.50 USD each
10. NOS RFT ECC85 6AQ8 - Single "O" getter = 2pcs., 6.20 USD each
11. NOS NIB Tungsram AZ11 OSW3121 - never used in box = 1pcs., 22 USD
12. NOS Tesla EZ81 6CA4 - erased label = 1pcs., 8 USD
13. NOS RFT EZ81 6CA4 - - = 1pcs., 8 USD
14. Used Valvo EL84 6BQ5 - Made in Heerlen, Netherlands between 1960 & 1967 = 2pcs., 22 USD for both
15. Used Valvo EZ81 6CA4 - Mullard Blackburn made, "D" getter = 1pcs., 12 USD
16. Used Valvo ECC83 12AX7 - Made in Heerlen, Netherlands = 2pcs., 22 USD for both
17. Used Tungsram ECC85 6AQ8 - = 4pcs., 5 USD each
18. Used Tungsram ECC83 12AX7 - = 1pcs., 12 USD
19. Used RFT ECC83 12AX7 - Single "O" getter = 3pcs., 10 USD each
Update:
tube___brand___condition___quantity___price (each)
01. ECC801S___Telefunken___NOS/NIB___1___125 $
02. EL503___Telefunken___used___2___87 $
03. EL34 / 6CA7___Tesla___used___10___48 $
04. EL34 / 6CA7___RFT___NOS___4___42 $
05. EL34 / 6CA7___RFT___used___6___30 $
06. E80CC(gold)___Siemens___NOS___2___39 $
07. E80CC___Tungsram(red)___NOS___3___34 $
08. GZ34 / 5AR4___Telefunken___NOS___2___125 $
09. ECC802S(balanced triode sections)___Telefunken___NOS/NIB___4___1200 $(for quad)
10. ECC803S(balanced triode sections)___Telefunken___NOS___2___2200 $(for pair)
11. EL84 / 6BQ5___RFT___NOS___10___30 $
12. EL84 / 6BQ5___Tungsram___NOS/NIB___9___34 $
13. E83CC___Mullard___NOS___1___62 $
14. E83CC___Philips SQ___NOS___1___62 $
15. E83CC___Siemens___NOS___1___62 $
16. ECC83 / 12AX7___RFT___NOS___60___23 $
17. ECC83 / 12AX7___RWN___NOS___4___25 $
18. ECC83 / 12AX7___Tungsram___NOS___4___30 $
19. ECC81 / 12AT7___RFT___NOS___50___12 $
20. EL84 / 6BQ5___Telam/Polam___used___20___15 $
21. PCC88 / 7DJ8___Tesla___NOS___10___10 $
22. EL84 / 6BQ5___Hoges(RFT)___NOS/NIB___2___26 $
23. AZ11 / OSW3121___Tungsram___NOS/NIB___1___20 $
24. EL84 / 6BQ5___Telefunken___NOS___1___88 $
....and more European vacuum tubes. Ask!
Pictures on request.
contacts at personal massage or at: "pen1.bg @ abv.bg"
Here is what I have left:
2 x NOS NIB Telefunken ECC803S matched and balanced military, gold pins
4 x NOS NIB Telefunken ECC802S matched and balanced
3 x NOS NIB Telefunken ECC801S
1 x NOS NIB sealed Telefunken EF804
4 x NOS RWN RFT ECC83 = 12AX7
4 x NOS RFT ECC83 = 12AX7
1 x NOS Telefunken EL84 / 6BQ5
1 x NOS NIB Valvo EL84 = 6BQ5
2 x NOS RFT EL84 = 6BQ5
1 x Tesla E88CC = CCa gold pins
2 x slightly used Tesla EL34 = 6CA7 brown base
30 x NOS RFT ECC81 = 12AT7
4 x NOS ECL86
1 x NOS Tesla EF80
2 x NOS Siemens Halske (Philips SQ) E83CC
2 x NOS NIB RFT EL84 = 6BQ5
1 x NOS NIB Tungsram EL84 = 6BQ5
4 x slightly used Tungsram ECC83 = 12AX7
2 x NOS Tungsram E80CC
16 x used Telam/Polam EL84 = 6BQ5 made in Poland in plant set up by Philips inn 60's
5 x used RFT FunkWerk EL84 = 6BQ5 from the 50's
2 x slightly used Telefunken EL503
5 x used Tungsram EL84 = 6BQ5
3-4 x used RFT EL34 = 6CA7
...and some more.
Pictures and prices on request. For quantities - discount.
Hi!
Some new tubes received.
--------EL84 = 6BQ5--------
BRAND Ia S
RFT 15,0 1,4
Tungsram 37,0 5,8
RFT FW 39,0 8,2
Polam 39,0 8,2
RFT FW 39,0 10,4
RFT FW 40,0 8,1
Tesla 40,0 10,4
Tungsram 41,0 9,0
Telam 41,0 8,5
Telam 42,0 9,6
Telam 43,0 11,6
Telam 44,0 12,1
RFT 44,0 10,2
RFT 44,0 10,8
Telam 44,0 9,8
Telam 44,0 10,4
RFT 45,0 11,0
Tungsram 45,0 10,6
Dario MW 45,0 9,6
Polam 45,0 11,4
RFT 45,0 10,0
Telam 45,0 11,4
Polam 45,0 12,4
Telam 45,0 11,2
Telam 45,0 10,1
Telam 45,0 11,4
Telam 45,0 11,3
Telam 46,0 10,6
RFT 46,0 11,0
RFT 46,0 11,3
RFT 46,0 10,2
Telam 46,0 11,4
Polam 46,0 12,4
Telam 46,0 12,0
RFT FW 46,0 10,8
RFT 46,0 11,2
Telam 47,0 10,0
RFT 47,0 11,4
RFT FW 47,0 11,0
RFT 47,0 11,3
RFT 47,0 11,8
RFT FW 47,0 11,0
Polam 47,0 12,2
RFT 47,0 10,5
Telam 47,0 11,0
RFT 47,0 11,4
RFT 48,0 12,6
RFT 48,0 12,0
RFT 48,0 12,0
RFT 48,0 12,0
RFT 48,0 11,3
RFT 48,0 12,3
Telam 48,0 12,0
Telam 48,0 12,0
Polam 48,0 12,8
Polam 48,0 12,4
Telam 48,0 12,6
Tesla 48,0 11,2
Telam 49,0 12,0
Telam 49,0 12,6
RFT 49,0 12,3
RFT 49,0 12,4
RFT 49,0 12,2
RFT 49,0 12,4
Polam 49,0 12,8
Polam 49,0 12,8
Polam 49,0 12,8
RFT 49,0 12,2
RFT 49,0 11,4
Telam 49,0 12,4
Tungsram 49,0 12,8
RFT 50,0 12,4
RFT 50,0 11,6
RFT 50,0 12,4
RFT 50,0 12,8
Telam 50,0 12,6
RFT 50,0 12,6
RFT 50,0 12,2
RFT 50,0 12,6
RFT 50,0 12,2
Telam 50,0 13,0
Telam 50,0 12,5
Telam 50,0 12,6
Telam 50,0 12,2
Telam 50,0 13,0
Telam 50,0 12,8
Telam 50,0 12,8
Telefunken 50,0 12,2
Telam 50,0 12,6
Polam 51,0 11,8
Telam 51,0 13,0
Telam 51,0 13,2
Telam 51,0 11,8
Telam 51,0 13,0
Telam 51,0 13,2
Polam 51,0 12,6
Polam 51,0 13,0
Polam 51,0 13,0
Telam 51,0 13,0
RFT 52,0 12,4
Telam 52,0 12,8
Telam 52,0 12,6
Telam 52,0 13,0
RFT 52,0 12,4
RFT 53,0 12,6
Where 100% is : Ia=48 / S=11
--------EL34 = 6CA7--------
BRAND Ia S
RFT 106,0 12,2
Mullard 13,0 1,2
RFT 26,0 3,4
RFT 102,0 11,6
RFT coin 94,0 11,6
RFT 20,0 1,8
RFT 76,0 9,6
RFT 82,0 10,6
RFT 94,0 11,0
RFT 86,0 11,1
RFT coin 104,0 12,8
RFT 88,0 11,1
RFT 90,0 11,1
Tesla 85,0 11,0
Tesla 104,0 13,1
Mullard 114,0 14,0
Tesla 106,0 12,8
Tesla 108,0 13,4
Tesla 100,0 12,8
RFT 118,0 12,4
Tesla 95,0 12,4
RFT 90,0 11,0
Where 100% NEW is Ia = 100.0 mA / S=11.3 mA/V
Also:
10 x NOS NIB Telefunken ECC801S
60 x NOS RFT ECC81 = 12AT7
4 x NOS ECL86
1 x NOS Tesla EF80
10 x NOS Tungsram E80CC
ECC83 - both NOS and used, some tested - Tungsram, RFT
PCC88 - Tesla, Mullard (NOS)
ECC82 - RFT, Tungsram
ECC85 - RFT, Tesla, Tungsram
Please let me know and I will make priced, depending on the quantity of the tubes. Pictures on request.
Thanks!
A lot of tubes in stock:
ECC801S TFK, ECC802S TFK, ECC80S TFK, RFT ECC83, Tungsram ECC83, RFT ECC82, ECC81 RFT, RFT-Telam-Polam EL84 (matched quads and pairs), EL34 RFT, Tesla. Metal base Philips GZ34, Tesla PCC88, Siemens ECC82, EL11, AZ1, AZ11, EL12, ECC85, TFK EL84, EL156 TFK, AD1, AC701, AC701k more and more.
