I've decided to sell my beloved Aleph 5 power amp since I'm building a Aleph X... I need the space... 😉
Aleph 5 is a 60W /ch Class A amplifier. There's is ample heatsinking and the temperature on the sinks never went over 55 C
Custom made chassis. Has XLR or SE inputs. Silver Teflon wires and silver speaker jacks.
There's a soft startup circuit in place and I believe 186000uF per channel. Two Triad Magnetics 24V 500VA transfos which are 130$ each at Digikey...
It is configured as dual mono.
This is a REALLY heavy chassis... Like 60-70 lbs heavy... So I'm not going to ship it out unless someone is interested to pay lots of shipping... Size of the enclosure is 17" x 21.5" x 8"
It only needs front panel finishing... I was thinking of wood front but right now it is a black anodized 4mm front panel...
Since there seems to be lots of interest, here's the pics! Please keep in mind that my phone camera sucks like hell...! 😉
Here side view with my finger traces all over the place... 🙂
Front view. Here's where you'll have to make a nice hard wood front panel and attach the blue Bulgin switch to it.
I have two fans on top but they are Noctua 140mm fluid bearings (extremely silent). I run them in a push/pull configuration. They have three speeds so you can play with them. This grill on top is not installed. It was just to show but I can give it away. Only have one though...
The Internals! This is where it gets nice!!!
Two Triad Magnetics 24V 500VA. It is currently setup for 120Vac but the transfos can be wired for 220-250Vac....
Bird view. There is a soft start (Necessary with that much capacitance) and a speaker protect circuit. The speaker protect circuit is fully fonctionnal and powered by its own transfo but I'm not using it... I prefer shortest path possible!
Left channel amp.
Independant power supply, each with 186000uF!
Shot of the back. SE, XLR, Speaker out with master switch, AC in and fuse...
The amp is fully functional and sounds amazing!
You just have to install feet, wooden front panel if needed. The chassis ground is not connected but that is quite easy to do. If someone is interested to buy and want me to connect it, I will do it no problem!
Pricing... Well... I never sold any of my finished amps so not too sure about this. I would like 500$ but it is negociable. Make an offer!
Ciao!
Do
Left channel amp.
Ciao!
Do
You forgot to post a price.
Didn't forget... As per my first post, I was checking if there was interest.
Now that I see there is, I will post pictures, add selling price. 🙂
I also have to answer all PMs that I have received regarding the amp. I will do this tonight.
Do
Hi I would be interested, what would be the shipping to Europe.
Luxembourg?
I have to weight it but the maximum Canada Post will take is 66lbs. I can probably find another carrier. You can check Purolater, UPS and Fedex as well.
For 66lbs
Canada Post ExpressPost International (the max) = 422$
Canada Post International Parcel Surface (Slow) = 212$
Do
Bonjour Dominic,
J'ai vu ton annonce pour le Aleph DIY. Est-ce un kit original de Pass?
Je demeure à Montreal.
Daniel
Daniel
Bonjour Dominic,
Daniel
Salut Daniel,
Ce n'est pas un kit officiel de Pass (A-t-il deja eu un kit Aleph 5? Je crois que c'etait plutot un F5?)
Le board suit le design original du A5 et est de tres bonne qualite. J'ai achete tout les composantes de Mouser,Digikey et Parts Connexion. Resistances Dale, Mills, CDE Silver Mica, Cap Panasonic 4 broches, etc... Pas de cochonneries dedans!
Tu peux emmener tes HP et ta source chez moi pour l'entendre si tu veux.
Merci
Do
Guys,
Used language is supposed to be English.
You're 100% right!
He's the one who started it! 😀
I'll translate the message for all.
why ?
maybe amplifier is strictly French ?
Yep! only french music can be played! Special build! 😀
That was a good one, made my day! 🙂
Ciao!
Do
Here's the translation
I saw your post for a DIY Aleph. Is it an Pass original kit? I live in Montreal
It is not a Pass official kit (Did he ever made a Aleph 5 kit? I believe he had F5?)
The boards follow Aleph 5 design and are of very good quality. I bought all components from Mouser, Digikey and Parts Connexion. Resistors are Dale, Mills, CDE Silver Mica, Cap are Panasonic 4 connectors, etc... No crap inside the amp!.
You can bring your speakers and source to my place if you want to listen to it.
So here's the translation!
Sorry for this!
Do
Sorry for this!
Do
Guys,
De kossé qu'tu r'conte là? Ah scuze... 😀
Ok, I just weighted the amp and it is a fat 73 lbs!
From this you can calculate approx shipping. From Montreal, Canada and postal code that you can use is H4T 1A6
Do
Do
I would love to buy this but I am afraid to ask how much shipping to brookfield IL 60513 is going to be.
Ouch $123 through ups.
Fedex is 110$
I can pay $40 of your shipping!
Ciao!
Do
let me think about it, the girl has started to notice how much I have been spending on audio lately. 🙂
Are the fans heat controlled or constantly on?
Always on but they are extremely silent. Fluid bearings and they turn at 900rpm and 700rpm
Ciao!
Do
