I have AAD speakers c800i and want to sell them because I need money!
they are in perfect nick, just been removed from boxes and still have boxes, they have been run, but not very often
I would like AU $800 ono + postage if its needs be
thanks cya
thanks cya
Hey
I still want to sell my speakers and there still in perfect nick with out a single scratch but now There is no boxs, they were thrown out ages ago
$450 o.n.o
Cya
$450 o.n.o
Cya
Hello
A problem has occurred 🙁 the top 6.5" driver has a melted or unaligned coil and I'm trying to find a solution to fix this but until then the speakers are now $350 O.n.o
Far out doesn't anyone know this brand, I'm selling these cheap as!
for proof here:
http://www.hometheatersound.com/equipment/aad_cseries.htm
Thanks Cya
for proof here:
Thanks Cya
Ok, the 6.5" Is fine now, It just had something lodges in its coil and perfect again, hell yes 🙂
Thanks Cya
Thanks Cya
Yeah I have all the info you could need im sure, Im not sure what you want but I have the Owners manual
Here are the published specs:
8 ohm nominal load
magnetically shielded
sensitivity 91
recommended power 10 - 250
27 kgs each
30hz - 20khz (no tolerance) but I assure you they go quite low nicely
dimensions 124.5cm x 23cm x 29.5cm
You could come see and hear them if you wanted to
also read the link in my previous post its the only in depth review i can find lol
thanks cya
8 ohm nominal load
sensitivity 91
27 kgs each
thanks cya
Awww 🙁 doesn't any one want these
How about $400 Im sick of waiting lol, but I assure you I wont drop any further, cause I have a friend who will buy them for $400 but I have to wait
Thanks cya
Thanks cya
