FS: 3 pair Mogami W2534 NEGLEX, Neutrik NF2C-B Hifi-Stereo Cinch, Cable aprox. 1 Mete
The HiFi universal cable which uses W2534 NEGLEX from MOGAMI. The used ultrapure OFC as material for signal conductor and shield guarantees an extremely low cable capacitance and best shielding against interferences. In addition, two PE monofilaments ensure a constant spacing between the wires and thus a uniform field strength over the entire cable. The result is a discolouration-free and detailed reproduction of your music.
cable no.: 2534
Colour: black
Length: approx. 1 m
Number of conductors: 2 x 2
Cable diameter: 6 mm
Jacket material: PVC
Shielding: Spiral shielding (64/0.18 A)
Insulation material: XLPE
Capacitance (1 kHz, 20°C): Core Shield: 65 pF/m | Core Wire: 13 pF/m
Inner conductor: Construction: 20 x 0.12 OFC | Size: 0.226 mm²
Connector: Cinch (Neutrik NF2C-B)
Connection first to ground, then to signal path, when unplugging first signal path, then ground is disconnected
Precisely milled parts
Unique Neutrik collet chuck strain relief
Gold-plated contacts
Each 25.- EUR plus shipping within EU (& GB)
And as always:
Private sale, warranty and exchange excluded.
