FS: 12" Woofers, NOS - AR, NHT, Jensen, Carver Amazing
I am selling a small collection of New Old Stock 12" woofers. See descriptions and pictures below.
$50/EA OR $100/PR SHIPPED CONUS, unless otherwise noted.
AR Limited 3 Woofer, PAIR, AR Part # 1210171-5.
This woofer was an adaptation of a very popular 12" woofer designed by NHT. This speaker is a beast. Cast, powder coated frame, huge magnet, rubber surround. It is designed for a ported enclosure.
This is a link to a spec document I found online by JHidley.
AR Classic 30 Woofers, PAIR, AR Part # 1210154-5.
This woofer is actually closer to an 11" in cone size, but 12" overall due to the basket. Designed for a sealed box. Really nice cast frame, composite cone, rubber surround.
AR PS1212 Woofers, Qty=3, AR Part # PS1212WF.
Used in a ported powered subwoofer enclosure. Huge magnet. Stamped frame. Poly cone. Rubber surround. Make me an offer on all three?
NHT 3.3 Woofer, Qty=1, AR Part # 1-11-024-2. SOLD!!!!
I have one of these beasts. Used as a side firing woofer for the 3.3 top of the line towers. Designed for a large enclosure. Poly cone, rubber surround, Cast frame is very similar in structure to the Limited, above.
Jensen 12" Subwoofer, Qty=1, AR Part # WOO JSUB9.
Nicely built driver with coated paper cone and rubber surround. Used by Jensen/Recoton as a ported subwoofer. Stamped frame. I don't have specs.
Best offer.
Carver Amazing 12" Woofers, Qty=8
For all you Open Baffle freaks!
Obviously these are not NOS, they are used.
These are mostly in great shape, all functioning very nicely. Two have cosmetic blemishes to the honeycomb, does not affect sound. Will include the crossovers as well.
$300 for all 8, SHIPPED CONUS
there's some interest in more pictures of the Carver woofers.
the foams are all in good shape, they have not dried up, however, the glue is lifting in places and they will need to be solidly glued back down. Steal of a deal for you OB fanatics. And crossovers are included if you want them.
The NHT woofer has sold.
I am adding a Radio Shack Realistic 12" 40-1034 woofer.
Poly cone, foam is in great shape. The PO installed it with caulking that I have tried to clean off as well as possible.
Pictures coming.
Ten bucks.
Specs:
12 Inch Polypropylene Woofer
(400-1034) Specifications Faxback Doc. # 60536
Impedance: ........................................................ 8 Ohms
Frequency Response: ........................................ 30 - 3,000 Hz
Free Air Resonance: ................................................ 30 Hz
Power Handling: ............................................. 75 Watts RMS
Input Power: ......................................... 150 Watts (Maximum)
Sensitivity: ........................................... 88 +/- 2 dB/1w/1m
Cone Material: ............................................. Polypropylene
Dimensions (HWD): 5-5/16 x 12-3/16 x 12-3/16 Inches (15 x 31.1 x 31.1 cm)
Magnet Weight: .......................................... 17.8 ozs (504 g)
Speaker Weight: .......................................... 71.8 ozs (2 kg)
