Frugelhorn question
Yes you can make it full height
Reducing the width of the deflector will also reduce the effective mouth area so it won't go quite as low.
dave
Ok, I'l stay with the recommended 10 1/4 width on the deflector as shown on sheet FH3. Sheet FH3 and your photo show the front point of the deflector touching the back of the bottom of the cabinet 15 9/16 from the front. Could I pull the deflector forward into the cabinet against the bottom angled panel in the speaker cabinet 11 3/16 from the front, as I would like to incorporate the deflector into the cabinet by extending the top and bottom panels? So, the overall depth would be 17 13/16. [11 3/16+6 5/8 deflector] I would leave the radiused sides as drawn on FH3. Or,am I messing up the design? Thanks again,Chuck
