Hello everyone,
Joined here in the hopes of having build questions answered! Is the front baffle meant to be sandwiched between the two sides?
When I look at the 5x5 cut plan the front baffle length is 898mm but I'm not sure these measurements match what is on the sheet FH3-1.
On that sheet it looks like the front baffle goes over the two sides.
I cut everything except the sides already so I'm wondering how to do things right!
It doesn’t really matter how you choose to mount the baffle. All the drawings have it inside the walls, for the flatp-paks we added a dado so it was half between, half on top. Solid baffle builds have it over the sides.
dave
dave
A day late and a dollar short, but a quick answer is that there’s more than one way to achieve the desired results; as Dave notes when designing the kit production version, we opted for what we hoped would make for an fairly easy assembly process.
As long as everything fits together someway in the end I'll be happy! I was a bit confused because the front view has dotted lines.
I'll probably veneer the front. This is my first build 😆
