Frequency Filter Full range loudspeaker
Hello everybody
I'm Vietnamese
I used some driver Full range, as Siemens klangfilm 22C, Philips 9710M01, Nirvana 10' Al, etc...
But, sound from mid to mid high is very much.
I was build a schematic parallel notch circuit.
I can adjust to fix mid sound with bass and tweeter
Seems like you need a shelving circuit. Usually a series coil in parallel with a resistor should do the trick. You can use Jeff Bagby's Passive Crossover Designer to simulate and find the right values for the shelving circuit.
