I wrote this player for reading audio files with FLAC extension (even WAV)
the player code has a good sound quality and a very high speed to decode the FLAC code,
still lacks the control panel to drive it in a comprehensive way.
To load a new file press the L key (FLAC or WAV).
To exit press the ESC key.
I have writing a graphics routine to evaluate the speed of this player.
Download:
Bonis Audio Free TGEN
Download:
Stable V1.0 😉
Download:
Bonis Audio Bonis Audio Player V1.0
Download:
hithe player code has a good sound quality
can you expand a bit?
can one turn off the visualization?
right ? 😉 ....is available on web site.
can you make it play from memory?
intend you a playlist ?
hi
bit .... much? 🙂
whichever you like.
I have added a VISION-XXL (resizeable) 😀 you find it already online, V1.31. (new M button)
Well done! A few minor niggles, but a good start to the basic engine.
I have spent a lot of time on this audio engine ...
thanks. 🙂
I meant implementation details. of course, if you're willing...I have added a VISION-XXL (resizeable) 😀 you find it already online, V1.31. (new M button)
You are welcome. The cosmetics can come in time, but the engine's got to be good to go! I'm no expert but I'm developing my interest in computer based source. I like Foobar so I'll listen and let you know if I hear anything worth mentioning. Cheers, Ben
exactly.... do you want to tell ? 🙂
EDIT
If you intend the core code, this is modular, i'm not use a unique language , i have coded the GUI with Blitzmax (him uses ASM and MinGW to compile), my extern modules made by C with CodeBlocks framework (and some calls have required directly ASM calls to unpack and read the FLAC code into static memory banks. I also imported snippets of RT in order to vary the speed of the play.
I have understood correctly your question ? 🙂
Optimized the GUI speed and fixed small bugs.
Download:
http://www.bonisaudio.com/free/pag4.html
Download:
I have rewrote the code, with the new engine i had to remove almost all other routines in favor of very high quality, i feel sorry for the other functions that i have disabled, but i'm very satisfied. 🙂
Download :
Bonis Audio Software
Download :
- Design & Build
- Software Tools
- Free FLAC Player
