Free: DIY AV rack/cabinet (West Yorkshire, UK)
I have an AV rack/cabinet I built about 20 years ago; free to anyone that would like to pick it up.
All the shelves are constructed from three layers of 12mm MDF; the center of each middle layer being cut out and filled with dry sand. As such; it's fairly heavy and well damped.
It's approx 168cm wide and 42cm deep. It sits on a set of recessed castors, and is about 53cm tall from the floor to the top of the top shelf.
The internal height between the top and bottom shelves is approx 42.5cm. The middle shelves (one fitted in the photos, one removed) can be adjusted in height. You can fit two items around 19cm tall with a middle shelf fitted.
I originally had it holding four items of AV kit, with a center speaker in the middle and a TV on top - to give an idea of the capacity.
PS Ignore the lengths of brown material - it's something separate.
