I'm still trying to clear out some equipment before a big move and I have three amps that I would be willing to give away for free, with local pickup. These amps weigh 90 pounds, so shipping is a no go. Pickup near Lansing Michigan.
Amps are Crestron CNAMPX-16x60. Please use Google for complete info. The amplifier modules used in this amp are made by ATI. Each module is 2-channels, and you can disassemble the amp and reconstitute these into 2*N channel amps as needed. A fun project (I did this with two of these amps already).
SORRY ALL ARE GONE NOW
I would love to have these !!
I live in Jackson 6 Miles from MIS in Napoleon, Sadly I don't drive, and would take me a while in order to get someone to take me to come get them.
If you just happened to come this way sometime ( Jackson's I-94 corridor) you can let me know and come by just drop them off if you are passing by, by chance. I am 12 miles straight off of the highway by Grass Lake Mich.
Is there a time frame when one needs to get them?
I can get someone, just need a little time.
Be at Mug-n-Bopp's in 20 exit150
If I can get a hold of a friend we'll come up and get them, but he seems to be down at this time as he gets really bad migrains a lot due to a truck accident he survived in 1990 in chelsea, he is like my brother grew up together since 1st grade, moms were best friends, and when he comes around maybe this week or in two, I can see if I can make him drive me up there.
Cheers !!
jer 🙂
P.S. I will PM the rest if we can set this deal up. 🙂
Cheers !!
jer 🙂
As of now, two are spoken for. There is still one available.
@geraldfryjr Unortunately I don't make it down to the Jackson area, so you would need to come up here. PM me if you are able to connect with your friend.
okay I will see what I can do, In reality probably won't be able to get up there in due time, when I do get a hold of my friend, I will check back with you then and see if you have it, sadly I missed out on the transformers you had, same situation again, else I would have contacted you and saved the shipping cost on them
Anyhow, Thank You it was worth a try.
See you in the threads. 😉
jer 🙂
jer 🙂
