Found retro 80s amp - Anyone know what this is?
Sorry to be such a noob but I found this amp and have no idea what is is other than I think its from the late 70s early 80's. Theres no model number so I think it must be a kit amp of some kind. Sorry no inside pics.
It looked like it had 2 transformers inside it?
Can anyone shed some light onto this about what it might be and if I could use it as a stereo amp with a couple of 1994 ish technics speakers?
It looks like it was designed for PA or similar use, with the jack plug inputs. It is not likely to perform that well in a domestic environment. However if it works, power it up and see what it sounds like. Any speaker of 4, 6 or 8 ohms should be fine. If you are unsure as to it's stability, use an old speaker to check it is o.k.
