Has anyone ever built this particular kit?
https://www.madisoundspeakerstore.com/full-range-speaker-kits/fostex-bk-20-folded-horn-kit-pair/
I can only comment on the cabinet loaded with a cheap Sammi 8" and Tangband W8-1772 (nice enough match)
the flat pack cabinet is sturdy and has reasonably good fit
BK20 with a cheap Sammi 8" wideband outdoors - ~ ground plane and on-axis mouth open vs mouth blocked with a pillow
BK20 with the same Sammi 8" indoors augmented with a Selenium ST324 as helper tweeter vs
a Klipsch Heresy I in the same spot as that BK20 - the Heresy was probably elevated 17" off the floor so lost some bass coupling
btw - this was equal drive so BK20/Sammi combo was more sensitive than the old Heresy
Wow, the Sammi is more efficient than the Heresy. Thanks for posting.
I built a similar back horn and was not thrilled with it. Scroll down to see a little picture of the BK16... or BK161... I forget the exact name.
https://speakerprojects.wordpress.com/2015/04/27/fostex-168z-projects/
