I'm building the Fostex 103E BLH and there is a discrepancy on the drawing. Item 8 is shown with an inside dimension of 375mm up to item 7, which is butted up to it, but on the cutting list is 375mm overall. Should it be 390 to make the dimension correct or am I worrying too much.
Paul
Paul
forgot to say, its the Fostex drawing here http://www.fostexinternational.com/docs/speaker_comp/pdf/recom_enclose/103e_encl.pdf
if it helps.
if it helps.
I encountered the same problem when I made mine (using the FE103 Memorial driver). I decided to use the sheet cutting scheme shown in the pdf (piece 8 being 375 mm long) ... still very happy with the result.
Regards,
Dirk
Regards,
Dirk
