Forte Model 4 in the house
Joined 2007
The recent audition of a Forte Model 4 in my system was sort of a revelation to me, and a step in the learning curve of how amplifiers and speakers work together. Thirteen years ago I built my first diy amp, a Zen V1 assembled on perf board. Next came the FirstWatt F5, and other iterations of the FW amps followed. I’m not a speaker builder, so the first speakers I had were a pair of B&W DM305, next a set of Focal 826W, and finally a set of Focal 1028BE. The core of my system has always been the FirstWatt amps at ~25 watts output. Now that I’m using the Model 4 with 50 watts available it’s apparent to me that my conventional speakers need more “muscle” for lack of a better term. I don’t understand that because for the most part the speakers are only using a fraction of that power most of the time. The Model 4 is a very nice sounding amplifier and seems to take control of my speakers. The mid’s and hi’s are not as smooth and sweet with the Model 4 compared to the FW amps, but the mid and lower bass sound much deeper and stronger. So now what? I’m contemplating the construction of an F5T. So is a 50 watt stereo enough or are 100 watt mono-blocks going to be better? It certainly has been a fun and gratifying journey to this point with much more learning/building to come.
My Nak PA-5 (150 watts per channel) can drive my 96db Klipsch speakers like Ben-Hur drives a chariot from 20-20000 with great clean control. My 13 watt tube amp has less power/control over the bass but sounds so sweet that it makes you want to listen all the time. I have done this same test with Usher Dancers which I would consider similar to your Focals and the additional power of the Nak woke the Ushers up. A Threshold 400 or 800a? F5 monoblocks? Feed the Focals, no bad choices here...
Inevitably someone will say buy or build more sensitive speakers. I won't say it. 🙂
A pair of F4 stereo amps can be wired for 50w or 100w. Just need a high gain preamp capable of 20db of gain.
I recent built a twin triode preamp capable of 30db of gain. It's easily adjustable via two resistors.
I upgraded the kit parts and it still cost around $200. Hard to believe the sound.
Point is a couple F4s are very versatile.
Well, with FW and clones, try couple of things:
1. Replace all 0.47ohm (or so...)/5W Panasonic resistors with wire-wound types. That means power supply and the amplifier PCB's.
2. Replace the input hook-up wire with annealed silver ribbons. There's no need to twist them at all, i.e the ribbons don't need any insulation.
For sure...I’d like to get my hands on that and give it a try! Maybe my buddy who owns a stereo shop will get one in some day. That’s where I got the Model 4 on loan from (Wayback Audio).
Any of the S/ series is great. I would think that his first watt stuff surpasses Threshold.
I am on this forum because I am looking into building a preamp. I know very little about amps however.
Good luck with the hunt for more power.
Is that the same B1 amp that is in the that is in the "The diyAudio build guides" thread? From what little I have read, the BA-3 seems to be favored. One guy said he threw his B1 in the trash because I he liked the BA-3 so much. Who knows if he was serious.
I’m using the F5 turbo v3 built as monoblocks. 125w/ch 8 ohms with 70w in class A -400w into 2 ohms. I am using a Jensen input transformer to get balanced input capabilities. I am running a pair of Monitor Audio gold 300 speakers (4th generation) which are 4 ohms and 89db rated. The monoblock F5 amps sound superb and have finesse, detail, slam and resolution that make them my go to amps for most listening.
I have an Aleph J also which is a bit softer on the top end but lacks the bass grip of the larger amps.
