Hello,
I have a buzz on a left channel on my Forté 1A 🙁
I have tried to detach it from the preamplifier, but the buzz remains.
The buzz is perfectly audible from my listens point.
The two channels work to the same temperature ( touching with the hand ) and I do not feel losses of balance.
Someone of you knows the reason?
Luca
Luca
Most of the time it is a ground loop issue. Create a pair of
RCA shorting plugs and use them on the inputs. If the noise
persists, then it's the channel. If it goes away, it's a ground
loop.
loop.
Hello Mr. Pass,
I have made a test with these net filters:
http://www.systemsandmagic.com/index_file/500_en.htm
Now all good!
Probably it is only a problem of the net electrical worker of my house.
Thanks of all!
Luca 🙂
Now all good!
Thanks of all!
Luca 🙂
