Two monoblock MoFo (mosfet follower) amplifiers are for sale. These amps will generate about 20 watts per channel. They are built on Michael Rothacher's design (see the build thread here) I strongly recommend you read the description of the amp if you're considering buying; it's funny as hell if nothing else! I'm selling these for less than the cost of the parts because I have many more amps than I need.
Spike feet will be included if you want them. There are inserts for them in the bottom of the amp, or you can use rubber stick-on feet.
I probably don't need to say this here, but I will anyway: Mosfet followers are amps that have current gain but no voltage gain, so you need to have a preamp with a significant voltage swing. If you don't then they won't play very loud. You are welcome to come by to give them a listen if you live near Philadelphia.
These have the large Hammond chokes; the original design was only 10 watts per channel, but double that is possible with the larger chokes. The power supply is a Meanwell 8 amp computer PSU, which is a much higher rating than needed. Highest quality parts are used throughout. The sides and front are palmwood, and I had the back panels specially made by Front Panel Express.
My carpentry skills aren't the best so one of the front corners doesn't quite join right; you won't notice it from the front when they're sitting on the shelf though. I'm going to try to reglue it.
Asking $295 + shipping. They'll be shipped in separate boxes; shipping probably won't be cheap as they're heavy and will have to be bolted to a board so they won't shift around.
