For a SMSL SA-36A PRO what power supply is better?
hi
i do not know your speakers impedance but i think a 24V/5A is sufficient for 4R or 8R speakers .
i personally have used a mean well lrs150-24 about 20 euro and i am happy. Fauxfrench has a lot of smsp by aliexpress and is happy with this and the promised power/quality is ok he suggested...and they are cheaper.
chris
yep....100 Watt to 200W is really enough for home use...
i personally lookat max possible current delivery. some smps are strong in Wattage but are not able to delivery more current then others...
its like a transformer compareision with the same VA= some transformer are better in deliver more current then others...
chris
Shenzhen ShuangMuSanLin Electronic Co., Ltd.
this smsl is a 2x20watt
why a 100 watt power supply?
I do not know what is "necessary" in your case...
what is your budget? power supply...as cheap as possible?
40W
for home use or small rooms its ok. i personally think that the difference between a 40W or a 100W psu is not as big to save money here.
on the link you send i see you chould have a TPA3118(cooling pad at the buttom of the chip- instead of TPA3116-top) so the chip can handle up to 26V operating level.
for more...read here:https://www.diyaudio.com/forums/class-d/104822-favorite-threads-posts-class-forum-2.html#post5683013
chris
40W
chris
i have not opened it, so i'm not certain of the chip!
in the rear there is a 12-24v
