I have an old Marantz cd74 with CDM1.
Does anybody know how to set the correct parameter for CDM1 llaser (focus,adjust ecc ecc)?
Andrea
Andrea
I only know that for adjust the laser output, I must connect DC voltmeter between the emitter of Q239 and the ground of chassis and adjust the potenziometer so the DC voltmeter reads 500mv +- 30mV.
In the pcb of CDM1 there are 3 potenziometer, one for laser out put, one for focus error adj and the other one for Focus offset adj.
Somebody know how check focus error value and focus offset?
Many thanks
Andrea
Many thanks
Andrea
Hi , the best would to have the CDM-1 service manual ,I have seen a link about a danish site ,I think , but sorry i dont remember .maybe try a search with "philips"?
When I close the door with a CD I can see from an angle that there is laser light. I can also see the laser flexing as is trying to focus. The motor however doesn't spin at all. Why?
The motor start only if i insert "Eric Clapton" cd, with other cd it doesn't start. If I wait one hour, so when the cd-player is warm, the motor start.
How is possible?
I have noticed that, if I tilt the cd while the laser is trying to focus, the motor start normally also if the CD-player is cold.
Andrea
How is possible?
Andrea
could be a lot of things . have a look here :
http://repairfaq.ece.drexel.edu/sam/cdfaq.htm
good luck .
good luck .
I solv the problem 😉
At the bottom of the turntable motor there is a screw.
The value was so high(300mV) and the normal value shuld be 0 mV
Also the laser output was so high (650mV) and the normal value shuld be 500mV
Now the CDM1 play very good, like new 😀
Thanks to ALL
Andrea
Thanks to ALL
Andrea
- Digital Source
- Focus on Marantz cd74 with CDM1
