Foam core..then Truck Bed Liner, That's All.
I would suspect the solvent in the spray-on liner. A prudent course would be to spray a scrap piece of board to see what happens. Harbor Freight sells a roll-on liner, which may (or may not ) be a different formulation.
Parts Express sells a roll-on texturizing coat (I forget the name) which I believe is acrylic-based. That may be a way to go. I'm considering it for prettying up a pair of ganky-looking particle board cabinets, so that if they must be black, they can be at least "black but comely".
Edit - whoa - I just checked out Parts Express, and they not only have the Dura Tex coating, but some damping compounds made by the same company. These may be a better thing to use on the horns. All seem to be water-based, so likely ok for foam core. Search for Dura Tex.
