Floor bounce and crossover frequency
The typical " bass dip" created by floor bounce is if the woofer is too high from the floor.
You want the woofer or woofers as low to the ground as possibly
Far as center to center spacing of mid to woofer, is not very tough.
As close as physically possible, as with all drivers.
They actual crossover frequency will be more justified by the woofer size and baffle step.
Horizontal response typically easy, most of it justified by vertical.
Drivers are mounted vertical and is where most your phase cancellation will be.
Basically mount them as close as possible, and crossover is more determined by physical size.
Reactions: mayhem13
If it’s a WMT tower…..don’t……turn it into a WWMT tower and a 3.5 way. All that’s needed is the appropriate .5 inductor for the bottom woofer and you can remove your BSC components…..they’re not needed. Solves all of your problems and a much smoother in room bass response
Reactions: Arez
Agee, woofers stay close to the ground. And your "listening position" is more ideally restricted
to a seated position as far as how high it can go for the mid/tweeter.
Assuming the tweeter is the typical listening position and that would be ear height seated.
Otherwise sound doesn't care if your upside down or not.
Ground/ ceiling same thing. You just stay close to the one of the larger planes. Typically the floor.
Reactions: Arez
