Flex Cable
Hi, I'm looking for a replacement part on my diy projector. Its a 15" vg150 viewsonic lcd monitor on a generic projector. I ripped the flex cable connecting the main lcd module to the screen. I've been googling it for awhile, emailed viewsonic and a few other websites. Does anyone know where I can buy flex cables?
If that's the mylar cable that goes from a circuit board to the actual glass of the LCD screen, I'd say you're pretty much screwed. If it's a cable that goes between circuit boards, you're less screwed but it's still not a commonly stocked cable. I get my flex connectors and cables from Digi-Key, and the most conductors they have is 50.
hey i have the exact same lcd; viewsonic v150. which cable broke? on the flat long boards that run along the top/sides to the glass? or the one from the flat long board to the floating circuitboard?
btw- that monitor is decent, but the contrast is rather low, it's kinda slow refreshing too. works well, but i'd rather go for something a bit better in performance.
mine was cheap on ebay ~$125 (second-hand/used).
if i were you, check out Waaalmart. They have a 15inch LCD for about $187 last time i was there, they also usually have a "discount" or "clearance" section in the electronics where you can get an openbox 15lcd for cheaper.
the main point there being that if you strip the lcd and somehow break a cable, you can put it back together, take it back to walmart and get a replacement. or your money back. 🙂
