First time crossover build… help/advice needed
Please look at what I am planning and provide thoughts/advice/feedback...TIA! Please be gentle as this is my first crack at this not using kits.
I am building a ported MT bookshelf speaker with the following drivers:
Dynavox LW6004HR-N 6-1/2" Honeycomb Cone Woofer
6 ohm
87.92 db sensitivity
50 to 4000hz
Dynavox TD2801XL 1-1/8" Silk Dome Tweeter
8 ohm
92 db sensitivity
2000 to 22,000hz
I used a calculator for a 2-way 2nd order Linkwitz Riley crossover, xo @ 3,000hz. I also used a l-pad calculator for tweeter attenuation and added resistors after the crossover...does this look right to you guys?
Based on vendor specs I will be building roughly a 0.63 ft3 ported cabinet.
