I'm graduating this year (electronics engineering) and I play guitar for a long time. I like to play metal (symphony X, angra, metallica).
I don't know much about guitar amplifiers; all I know came from google. It seems like guitar pickups act like a lowpass system with a ressonant frequency varying from 1kHz to 5kHz, and this transfer characteristic must be compensated (how?) in the pre-amp stage.
I'm trying to design a pre-amp, as simple as possible, just to start learning about guitar electronics and, in the future, design my own pre-amplifier for my guitar.
I have scketched a very simple pre amp based on poor solid state components, and it has a very good sound.
All I want now is suggestions on what to do next or what is wrong in this schematic and should be changed.
Please take a look:
Please take a look:
Hola!
I think your little guitar ampifier is good.
You say: 'sound is good'
Why you want to change?
Some problem?
Only thing I do not know about is where you connect output?
Some power amplifier?
What is input impedance of your power amplifier = The Load?
What would I change?
I do not know.
TL081 / TL082 / TL084 will be good for this type of guitar amp.
12 Volt.
What power supply you use?
You want to use battery?
You can use TL06X variant: >>> takes only 200uA supply current! ( 0.2 mA )
And you use one 9 Volt Battery.
And you can put Battery + Guitar Amplifier inside your guitar!
Then you can turn and control, when playing.
Datasheets .. for VARIANT of Op-Amplifiers:
http://focus.ti.com/lit/ds/symlink/tl084.pdf
http://focus.ti.com/lit/ds/symlink/tl064.pdf
Some problem?
I do not know.
12 Volt.
thankx for the answer. I forgot to mention some things. First, the output is connected to a standard stereo amplifier, I think a load impedance of 20k to 100k (which is connected to the 22k resistor shunt to the diodes).
the reason of 12V: it's the source I have here... it could be 9V without any problem...
about the 'good sound': the sound is clean (not noisy). It has a good distortion, but it doesn't have that metal sound i want. I have read about pickup electronics and pre-amp pickup corrections. What kind of corrections (filtering) are made in guitar preamps?
and the last question: what do you suggest to add to this schematic and how it is done?
thankx again for the answer.
cufunha said:about the 'good sound': the sound is clean (not noisy).
I do not see anything add to your schematic, besides some metal effects you want.
One idea I have used,
when have mono signal input + output to stereo:
Put 2 output capacitors and output level potentiometer:
to left + right stereo channel
Same as using a mixer with 1 microphone (mono mic) input.
- you have 2 output to left/right.
- can use those 2 potentiometers to put this sound source into LEFT/RIGHT panorama
... when reording in stereo.
It is like panorama studio mixer.
I give you one good link to find metal guitar effect ... and some other good electronics circuits.
Because I know only little about guitar circuits.
Here I hope you will find a lot links for Guitar Circuits applications
http://www.epanorama.net/schematicsforfree/Audio/Circuits/index.php
http://www.epanorama.net/links/music.html
Regardas honores.
Lineup
from a relative newbie to guitar stuff..
but a seasoned analog engineer;
C2 can be decreased. 0.22, or even 0.1uF, smaller and cheaper
C5 should be incresed, this is rolling off your gain st 160Hz right now. Becuase there is a fixed DC offset, a 22uF or 47uF electrolytic can be used.
R8 will not provide a reasonable volume range due to its interaction with the feedback diodes.
You will never get more than about 0.6Vpp out of this. Is that enough?
i changed R8 to 500k now and now i can clearly hear the overdrive effect i want (but too noisy because of the very high gain). the capacitors are now changed as you pointed.
Can u explain me what should be the low cutoff frequency of this amp? I thought it was about 200Hz or more, but you´re talking abaout 160Hz.. and how about the high frequency cutoff? 10KHz is fine?
PS: inductor and capacitor near source simulates guitar pickup plus cables.
