Finally, some progress! Pics-
No, it's a bath towel that's spread out on a table. I wanted something soft that would not scratch the LCD. I sprayed the towel w/ anti-static spray first though, and tried to touch ground as often as possible, and deliberately trying not to touch the circuits at all. Besides, the humidity here is around %80 today, so everything should be alright. 🙂
Video Freak, do you know of anyone who has done a gateway like this? maybe some pics or tips would be helpful. I was just going to cut the copper ribbon in half, then torch the laminate off the edges of the cut area, clean the raw copper, then solder the smallest ribbon cable I can get a Radio shack, between the two pieces, and plug in the other end to the side circuit board.
