I have a small Final 80 element that got broken one year ago. Now i was trying to pull the device apart and start repairing it on my own. Now since Final doesnt give any support on this element i am looking into making my own membrame.. I am a total newbe for this matters. so i am going to learn alot with this small speaker. Most of the stuff will be trial and error. but first of all i am looking for an address where i can buy the mylar. and second what will be the best way of coating the membrame. I look on the forum. and saw several things with glue and things like that. but what makes me curious if i start to coat the membrame with some glue or it. wont that make the membrame to stiff and or too hard. ??
any suggestions are very welcome 🙂
this should get you going...
http://user.tninet.se/~vhw129w/mt_audio_design/
a club near yo.u...
Audio Vereniging Midden Nederland
Hans van de Vis
Reyer Anslostraat 83
Utrecht 3522 DH
Hans van de Vis
Utrecht 3522 DH
MY Audio Design....
I only just noticed the links that I posted are the same. Sorry but when I coppied the specific page that I wanted to I only got the main page each time and I did not notice, Mats has info in DIY supplies such as film adhesive and diaphragm coating. You will have to sort through the site to find them but they are there.
all very usefull links. some i already found googling 🙂 but many thanks for the taken time. i am going to look into this if any questions i will surely come back here...
the are are aluminized films and ITO-sputtered films.
But both ´coatings´ have their serious disadvantages and as far as I know no commercial ESL uses such precoated films any more.
You´ll want the coating only where it´s needed! So keep spacers and the outer rim of the panel out. That´s a great plus of coating the film yourself!
Coating is very easy with the right stuff. For DIY I recommend the glue-formula, which is easy to mix, easy to tailor to the needed parameters, totally transparent, water based and non toxious (could even be swallowed without harm), stable and extremely cheap.
You can paint, roll or spray this coating on.
Use the search-function for ´coating´ and ´glue´ or similars.
jauu
Calvin
jauu
Calvin
How big is this Final 80 panel? If it fits my stretcher then perhaps I can help you along. I'm located in the south of Holland.
- Planars & Exotics
- final 80 repair
