Hi there. I am looking for a schematic of a circuit referred to as "FETbloke". I have heard about it in online forums....but I haven't been able to find a schematic. Thank you for your help. ---Tom
It might be a misinterpretation or misspelling. Bloke can be a block (it sounds close to dutch 'blok' - meaning block), so a "block of/with FET's". Someone may have named a fet-only amplifier as such, and then it becomes a magical gem hunted by the bravest.
It might be readely available at your diyaudio-doorstep!
Edit: picture search does not yield relevant electronic circuits however...
It seems to have been popular on the GroupDIY forum and was called Big FET Bloke or Big FET Bloak but links to schematics are dead.
See here FETbloke for summing results then search via wayback machine...you'll find some schematic...then google images for Fetbloke😉
Leadbelly.....yes indeed, that's where I saw it.
Aparatus....thank you, I didn't have success with that, but I'll try it again.
...google images for Fetbloke😉
Uh, no, DO NOT DO THAT!!
- Analog Line Level
- FET Bloke
