Fender Rebuild
I recently acquired a Fender Vibrasonic 5G13 circuit. I ramped up the voltage to test the power transformer/output transformer (I purchased it as is with missing tubes) and it gives output. I am going to rebuild the power supply and recap as I want to play it, not collect. Any suggestion for the 20mf @ 600VDC axials. Very expensive caps. Any suggestions for the coupling caps ie types to retain close to original tone. I realize the caps today are different than vintage caps but the caps in this amp are 48 years old and have probably drifted seriously.
Ah yes sorry, I got sidetracked on this topic 😱
2 x 47uF @ 450V in series will give you a nice 23.5uF @ 900V. Use a resistor across each (220K @ 2W is good) capacitor to equalize things.
I'll dig through my emails when I get home tonight.
Cheers!
