Fender FM212 - Deluxe 90 PowerAmp problems
Similar link:
http://www.diyaudio.com/forums/soli...ting-power-amp-output-fender-deluxe-90-a.html
It's a problem I encountered a few times and this time I try to solve it.
It's allways in the same type of Fender poweramp.
Now it's a FM212R.
It uses the same power amp as the Deluxe 90 and even the same component numbers.
After different attempts over time the amp is still behaving bad.
I.o.w. - It plays great but within 10 - 20 seconds it starts to draw excesive current and Q20 becomes hot and hotter and hotter…
(Yes the heatsink is attached.)
When I use a freeze sparay on transistor Q14 and the surrounding components the amp behaves normal for 10 seconds or so.
It is a thermal problem but where?
I suspected a bad Q14, but that didn’t helped at all.
I finally changed the outputs, Q20 and Q21 and it helped a bit but finally it took 10 seconds more before Q20 became hot again.
So at the end you suspect every component and test them all, one by one.
Of course these from the power amp stage...
They all measure OK.
Very frustrating...
"I can’t see the trees anymore in the wood"
A hint can do wonders when you tried allmost everything with no results...
It's sunday today and I have other "Garden stuff" to do.
Tomorrow I’ll have a look at it again…
Allthough the different parts all measured OK, it will be a problem that when voltage is applied one of these will become faulty.
Aargh, these are pesky problems…
More details tomorrow evening…
Thanks for some hints.
