ok this message is english is for the dutch members, because im looking for a shop to buy velpon school glue. problem is i can only order it by the 12 wich is expensive and way to much. does anybody know a shop where i can get it ? like V&D or bijenkorf or whatever kind of shop that you can vind in Den Haag or in the whole country ?
tried so many glues now al water based , but they just dont work. so i really really want to try the velpon before i dismiss this coating type.
Don't know what the coating is fore, but would Wella hairspray be useful?
I used it for my hair when it was all straight up. It could withstand little rain and a lot of wind. Looked like glue, btw.
Hi i think Casco RX glue is more or less the same, a PVA glue. Comes in waterbase and non water base
Could be worth a try
AkzoNobel Homepage look under products, all brands, Casco adhesives
I just say that i have had success with elvamide tough. Takes some time to dissolve but easy to apply and durable
The guy who came up first with Velpon probably is Geert Vijncke.
While he was positively minded about velpon at first, he reported loss of efficiency on his esls later on. His panels were nicely build with insulated wire stators.
Don't know the application so a good advice isn't possible, but;
PVC glue for PVC pipe (like waterdrains) perhaps? To be found at Gamma, Praxis and the likes.
OPtherwise epoxy stuff for laminating fibreglass might do the trick. At the same DIY-hardware stores.
- Planars & Exotics
- Fellow dutch people HELP! cant vind velpon glue
