feedback resistor value question
Hello,
In the pre-amp section of my integrated amplifier there are (2) 17k8 resistors which are the feedback resistors. 1 for each channel.
I cannot find a good quality 17.8k resistor. What will happen if I change this value slightly?.
I was thinking of 18k.
Is it a worthwhile cause to upgrade this resistor to a caddock or vishay?
Any input or experiences would be appreciated.
KevinLee🙂
Nothing much will happen. For peace of mind you should check the resistors which tie the - input to ground in order to calculate the gain but the change will likely be minute. Resistor sound is very much a personal choice and you should buy a few different makes and experiment in order to take the right decision.
KevinLee said:
Hello,
KevinLee🙂
The difference between 18k and 17k8 is 0.09705 dB approx. = not very much
Vishay makes good and normal industrial quality resistors, work good in most cases.
What type or brand did you have now?
Hello,
What are peoples favorite resistors for this application?
Caddock MK132, Tantalum, Vishay Bulk metal Foil, Draloric SMA-0207, Vishay CMF Type RN, are all types I am considering.
Any preferences of the above types for feedback circuits?
KevinLee
PS. I am using OPA627 as my opeamp.
analog_sa,
I have just installed the OPA627 via Brown Dog adapters and am letting it break in now. You are right that I might not like it. I previously had a AD826.
What is your choice for op-amp in pre-amp stage?
Kevin
