Favorite film capacitors for DC blocking?
For many years my favorite DC blocking capacitor was the original IAR Wondercaps. Alas, I have finally depleted my NOS stock of these parts and am looking for a replacement.
Is there any consensus at all regarding which brands sound the best? Perhaps someone has posted some comparisons somewhere on the net?
I always thought that the Wondercaps used a teflon dialectric, but I don't know for sure. This is primarily for solid state work, so I'm not sure that I should consider paper/oil caps or stick with standard polypropylene, polystyrene, or teflon film types.
I sure don't want to have to purchase a few of every type available and spend many days making comparisons, so any advice is appreciated!
Take care,
Doug
I have seen reports on teflon di-electric and they seem to be tops.
Most cannot afford these and accept next best as polypropylene.
These are good for coupling/DC blocking.
It appears that the X & Y rated types intended for mains use perform as good audio caps.
Then come all the other film caps that are there to save space and/or money.
I would be very surprised if IAR are teflon.
A year ago i've rediscovered polyprop LeClanché capacitors, from Switzerland.
By stumbling on a NOS batch, noticed at a later date that the brand has been gaining audio popularity.
LeClanché's tinfoil line caps are pretty ok by me, although i doubt that i'll buy them again for the going rates. Not to mention the size downsides.
Hi
I have been experimenting.
I found that I much prefered the sound of polystyrene caps and teflon second and polypropylene/polycarbonate third.
The problem with the polystyrene and teflon is the size. I do have a lot of all the above types that I bought some time ago but most are too large to use in values over 1 or 2 uf.
I experimented further and found that I prefered even more the sound of polycarbonate (1 to 10 uf) in parallel with polystyrene. ( 0.05 to 0.01uf )My second choice was polypropylene ( 1 to 10 uf ) in parallel with polystyrene. ( 0.05 to 0.01uf ) I found that parallelling gave me the crystal clear treble that goes with polystyrene/teflon coupled with the low base that goes with higher capacitance values.
I could not find any electrolytics that gave as good a performance as the polycarbonate or polypropylene.
I performed listening tests on a Krell and a Passlabs preamp that does not need a blocking capacitor. I could not hear a real difference when the parallelled capacitors were inserted. It may just be my ears - who knows. I found a greater difference in the preamps that I have designed and built myself when I chage semiconductors than by changing capacitors. Nelson Pass I believe commented that in his view semiconductors were less linear than capacitors. I find the same. ( NP if I misquoted you apologies and please correct me )
I found the best sound and also the best value for money by using parallel polycarbonate and polystryene.
Hope this helps
Don
Hi
Until I read Andrews post yesterday I had not realised that polycarbonate capacitors were no longer available. ( I have large stocks of various types and rarely need to buy parts )
However I still have a capacitor test rig set up at the front end of my preamp so last night I did further testing of various combinations of capacitors to find a cost effective and this time available combination. I found paralling polystyrene (or teflon) ( 0.05 to 0.1 uf ) with polyester sounded OK to me. The polystyrene/teflon gave a clean treble. The base was good if I used good quality polyester capacitors. I found that to my ears this sounded better than simply using polypropylene. Also much more cost effective.
Cheers
Don
About the only application for capacitors with gold plates I could think of is very high temperature glass capacitors; literally layers of very thin glass and metal foil that are heated until they fuse together. I have seen a very few glass/tin capacitors, usually in picofarad values. I can't imagine any other application; gold isn't that good a conductor and would only be useful to prevent surface oxidization.
I wonder if the MKP from Wima are the self healing type that use a mixture of foil and metallised and run caps in series and an interlayer that is not polypropylene?
Some or all of these attributes might explain why they came at the end of your preference.
