For Sale Faulty Topping L30 II
Things you have for sale.
Stopped working last year, barely used the thing at all, planned to try and fix over summer but dont have the time or energy.
There was no catastrophic failure like other units, although this is the "fixed" II version you can still find reports of them failing.
One day when I flipped the switch and it showed no sign of life, no blinking power LED that usually indicates a fault.
AC supply is still working and I had a look at PCB, no burnt components, I would guess the issue lies in the MCU and not engaging the required relays to give an output... in which case could probably be bypassed if the amp circuit is still ok (would not trust this amp without them though considering its history)
Not the first Topping product to randomly fail on me and far from the first time hearing it happen to others....
Asking €50
Other ads:
