Does anyone know of a place where I can buy parts for fastening a transformer to a chassis?
I need a disc plate, like the one pictured in this amp: http://imgur.com/5IMd6qD
Thanks.
Thanks.
The first three hits from a search engine using seed of "toroid mounting hardware" :
http://www.alphacoredirect.com/contents/en-us/d51.html
http://www.toroid.com/mounting_hardware/mounting_hardware.htm
http://www.cornucopiaplastics.com/robison/products/coil_mounting_products/coil_mounting_products.htm
Dale
Dale
Thanks for the answer. So it appears I had to search for a "washer". It was a bit challenging to find.
I finally found a shop in Denmark that has what I need: http://elektronik-lavpris.dk/p114506/RK-RONDEL-112_Rondel_for_fastsp%C3%A6nding_af_ringkerne,_112mm/?
Warning: If you are making something of your own in a metal chassis, MAKE SURE a metal bolt does not touch both the bottom and top of the chassis. Either use a nylon bolt or make it short enough. If the bolt touches top and bottom, it completes a one turn short on the transformer.
Thanks for the reminder!If the bolt touches top and bottom, it completes a one turn short on the transformer.
