Hi all, is there any advantage to using fast recovery diodes eg. MUR8** series as opposed to a normal bridge rectifier when constructing a power supply consisting of a transformer, rectifier, filter capacitors for a class A/B amplifier
Any views please
thanks
Alan
Any views please
thanks
Alan
Use the search, Luke
If you'd bothered to use the search or recent posts you'd find that there's already a thread on this
You'll find some different opinions
No advantage. 50 or 60HZ does not require fast recovery.
Thoglette, I did a search, obviously with the wrong criteria. Obviously I'm rubbish at most things, but there again I'm happy. To ere is human to forgive------------
Alan
Alan
Searching is a special skill that not everyone has. Most of my searches return thousands of non-related links.
(I do miss Alta Vista)
Keep on looking pals and please come back with your finds 🙂 - just skip the ads please...
Divine.To ere is human to forgive
Closest I'll get to divinity. (+1 on Alta Vista)
I have had problems with high voltage supplies and slow diodes.
I got huge glitches on the output.
The problem is more common in valve amps than in solid state.
- Power Supplies
- Fast recovery diodes
