• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
FAQ power inductors
Q: What is the operational role of power inductors in Class-D amplifier circuits?
A: In Class-D audio amplification systems, power inductors perform critical filtering functions through these primary mechanisms:
LC Filter Core Function
Collaborating with capacitors to form:
  • 2nd-order low-pass filter topology (typically 50-500kHz cutoff)
  • 40-60dB attenuation of PWM carrier residue (300kHz-1MHz range)
  • 90%+ suppression of harmonic distortion components
System Performance Optimization
Key selection parameters for modern high-performance designs:
  • Miniaturization: 1210 to 2520 case sizes with <1.2mm profile
  • Efficiency Enhancement: <0.05Ω DCR at 3A load conditions
  • Thermal Stability: Maintain stability from -40°C to +125°C
  • Saturation Resilience: 20-30% headroom above peak current (I_sat ≥ 5A)
  • EMI Mitigation: <5nH parasitic capacitance configuration
AEC-Q200 compliant automotive-grade options
These magnetics enable Class-D amplifiers to achieve:
✓ >90% power conversion efficiency
✓ THD+N <0.005% @20hz-20kHz
✓ 85°C ambient temperature operation
✓ MIL-STD-202G compliant vibration resistance
Typical applications: automotive infotainment, professional PA systems, and compact IoT audio solutions.
