For Sale Fanless i7 NUC music server with internal OCXO master clocks
Things you have for sale.
Howdy,
I purchased this only two months ago with the ambition of it being a little project - I now find myself in the position of having three DIY music servers and no time to complete this build!
  • CPU- i7
  • MB - NUC7i7BNH
  • M2 SSD included - 256GB Sabrent
  • Memory : 8GB Apacer
Its has three onboard Connor Winfield clocks, which are all supplied by a 3 pin miniature connector (same type Teddy Pardo uses) this needs 12-19v @ 2A, then the NUC section is powered by its own DC Jack power supply 12-19v @ 3A.
No PSU included, but I can throw in single PCB of Salas L-adapter, this is a very well regarded linear power supply - all you need to do is populate it, attach to a transformer and put it in a 25 x 25cm enclosure and supply the two rails that the NUC and OXCO needs. Total cost probably about £250, but you could also use an aftermarket power supply of choice if you don’t fancy building your own, or go the whole hog and supply both the clocks and NUC separately (probably little need for this to be honest as there are already regulators on the clocks). I’m happy to advise on the build.
A very good sounding NUC. I’ll ask only what I purchased it for, which was a bargain.
£350/$400
Item is located in Oxford, UK.
