Edit *recommendation
Hello,
Please help me to decide which enclosure for Faital pro 18fh500 to use.
FaitalPRO | LF Loudspeakers | 18FH500
The room is 22m2, the system is active, 3 way, front loaded horn for 300-1k8, and 1" CD horn above.
Options:
-OB (At this moment I listen to them in OB.)
-vented 50cm-deep Exp horn.
-vented.
-sealed box (does not reach the lower notes so good, in simulation).
-other ideas?
Thanks!
Hello,
Options:
-vented.
-other ideas?
Thanks!
With an 18" driver a side at home, sealed + EQ is how I'd do it.
You're already making a fairly expensive system - a measurement mic should be included in that.
Chris
Chris
Thanks! I have a Mic.
I will try a 200liter sealed box.
Regarding speaker placement on baffle. Is it better to put it as high as possible, to be near the mid-horn mouth? Or better lower on the baffle, near the floor?
Thanks!
Thanks!
