F5X Transformers
This is an offer from Toroidy for F5X transformers. These are the characteristics of them:
600VA audio quality transformer
Primary: 230V, 50Hz
Secondaries: 2x16V, Bifilar wound
Shields:
- Electrostatic shield between primaries and secondaries with earthing
connections
- Electromagnetic shield on the perimeter outside the secondary winding
Isolation:
Temperature class B , 130⁰C per IEC 085 Ta 60⁰C VDE0570 EN/IEC 61558 IP 00
Test voltage:
Primary - secondary: 5000V
Secondary -Secondary: 500V
Dimensions:
Outer diameter ~145mm
Height ~57mm
Electrical connections: Free-length enamel wire 200mm long
Fixation: open core not potted, centre bolt, disk & rubber gasket.
Therefore, the transformers accomplish all the specifications made by Patrick( EUVL). The price for each piece is 69,40 EUR if we buy 10 to 20 pieces, and 65,80 EUR if we go for 20 to 30 pieces (prices with 23% VAT included).
The shipping is a little expensive, because a package up to 30kg to Spain is 28,00 EUR (The app. weight for a transformer is 5Kg) .From an earlier post in the forum it's 15,00 EUR to Germany.
Perhaps we can find a cheaper shipping method.
If you are interested, please, put your name and quantity below:
- EUVL 2 transformers
- Mravinsky 2 transformers
Antonio
