F5 variations for sub 4 ohm speakers?
Not sure where to post this but had been considering a F5 build some time ago. Last weekend I picked up some speakers I've been wanting for, oh, 30 years. Infinity RS-IIIb which are 4 ohm but known for dropping much below that, thus killing amplifiers. I believe efficiency is 89 db.
Can one of the F5 variations be done as to get 80 to 100w with the sub 4 ohm covered or do I need to look at another design?
I have an equally old NAD receiver rated at 20w, which is great for some acoustic recording and electronic but I'm afraid to turn it up and don't feel I am getting the low end like I should. It isn't giving me what i need for rock.
Spending half a day driving around and bothering amp repair people for recommendations and I keep on getting stirred toward McIntosh. I do not expect to be buying anything that expensive in this lifetime.
I don't have a pre-amp, and the NAD receiver does not have the capability to bypass the internal amp. Will be playing FLAC and would like ability to use them for a television when I get around to purchasing one.
One of the F5t should be better than an F5 for driving very low impedance speakers.
But don't choose a version that uses a much higher supply voltage.
The standard F5 does ~27W into 8ohms and with a decent supply will do pretty close to 50W into 4ohms.
A 2pair or 3pair version will perform even better when the impedance drops well below that nominal 4ohms.
BTW
38Apk into 0r1 is only 3.8Vpk.
That has no relevance to driving a speaker.
19Vpk into 1r0 is very relevant to driving a widely varying 4ohms speaker, even though the raw number is only half that headline figure into an effective short circuit, i.e 19Apk vs 38Apk.
What do you mean by 2 pair / 3 pair version? Based on memory, I would guess the 2 pair is what was being referred to as cascode? No recollection of a 3 pair version - if I have the concept correct.
I am rereading the types, but I remember a lot of evolution as those with understanding were able to change things. For some reason I thought I had my mind set on F5 V2 cascoded. Out of reading time for the day 🙁
My electrical engineering knowledge is only slightly above replacing a lightbulb with the help of ladder and two people to rotate the ladder while I hold the lightbulb in place.
All suggestions will be appreciated and I'll try not to dumb things down excessively.
To start with, the numbers you have given me are your way of showing a person that speaks electronics that you understand these speakers kill amplifiers and that something such as a F5 V2 cas design is highly resistant to death from being used with these speakers?
I do recognize the usernames of those that replied, I think I spent November to January obsessively reading threads.
Check out TeaBag's layout/boards.
iirc, they take 6 or 8 pairs.
First step, imo, look up the reviews for the speaker. The one's in the mags, they generally do both a freq resp and an impedance curve. Don't guess, or go by what "people say". See what it actually is. You need to know for certain.
Then you want some margin anyhow.
Next step is to compare the current requirements vs. voltage through the actual MosFets that you are going to use. You want to look at the SOA graph on the mfrs spec sheets. Multiply current x the number of devices in parallel and de-rate. Now you know what you think the number of devices at what voltage (rail voltage) you will need to drive your speakers at what power resulting in what SPL at a distance of 1m. Then you drop that figure as you go back in space, unless the reverberant field is high (very high).
This tells you what you can expect as max SPL at your listening position with a given power amplifier (any given power amplifier).
This relates back to your build WRT the devices, the rail voltage (max swing, therefor max power into some Z - ohm's law tells all), and the number of devices used.
Remember now, more devices biased at a level equal to the baseline F5's bias point = much more heat = larger heatsinks. Manhattan size (not really, but a bit of exagerration helps here). Or a fan. I don' t like fans in my listening room.
In the case of a "power hog" speaker, it's probably ok to let the amp "switch " in to class B at higher output levels, and reduce the quiescent and average heat while playing...
This should give you something to do for a bit...
Oh, you MUST use genuine JFETS from Toshiba (not the asian fakes) OR the LSK / LSJ series sold here on DiyAudio 's store (or from other bonafide vendors with stock).
Hi Jeffs. I worked in audio retail when the RSIIIb was current and did not have reliability problems with amplifiers. Over the course of several months, we used the Nakamichi PA-7, Haflers 220 & 500, NAD 2200, and larger NAD receivers with success. I would be confident with an F5T V2 or higher.
I'm backing off a bit to learn some basics, starting with an amp camp build. As far as a pre-amp stage for plugging my macbook into with 3.5mm jack considering an OB2, will the OB2 be sufficient for both an F5 t build and the amp camp? It's not a permanent solution, but don't want to build stuff that's not needed. I can add DAC in the future if I keep using it but a good chance it will go to my dad.
Do you mean the O2 headphone amp as a preamp? That will work beautifully.
The ODAC is also quite wonderful.
Thanks! I'm feeling more confident in moving forward with the basic stuff to learn what I'm doing before taking on a F5T variation.
In the mean time I'm getting by with the old NAD 20w integrated unit which is fine for simple music at reasonable volumes.
Another thing - McIntosh stuff looks fantastic. But that's all it has going for it.
Anyway, as for version to build, "power" isn't as important as current capability, and to that end, lower voltage and more devices is the way you need to go.
A v2 with 24-30V rails will most likely be more than sufficient, as Class-A watts are significantly more powerful than something like your NAD. If you get bigger than that, you double the cost, as you need to make monoblocks. (Not that there's anything wrong with that... 🙂 ) If you do go bigger, there is little need to cascode, just add more outputs, and keep the voltage in that 24-30V range.
While at first I was hesitant to have the impedance measured, now considering it now for speaker specific design unless that is getting too geeky - but in this crowd I doubt it is considered unusual. I have no idea what that will cost, but it is surely $100 I would rather spend on any other random component. Required or not? The only thing I can find published on them is 4 ohm, 89db. They are tall, shallow cabinets with two 10" woofers, a dome midrange and ribbon tweeter, adjustable crossover network.
So far what I have is sounding great until I want it to reproduce loud rock, say recorded from '67 to '80. Example, most Led Zeppelin is washed out. Some classical, as in large symphony is washing out. Is washing out my own term? Don't know, but is my description. Speakers are not as far away from the wall as ideal. About 2' for everyday listening. I'll move them out a little more for critical listening of a couple of songs but run into other placement issues with that. I've only started to adjust the crossovers, usually to try to tame the ribbon tweeters on certain recordings.
I doubt I am the first person to reconsider, but after speaking with the last person to comment - I need more current as opposed to voltage, so scratch F5 T v2 cascoded.
The current consideration of a F5 Turbo V3 or a pair of F4's run in balanced.
For a pre-amp I am now considering adding tubes. Suggested was the Impasse - I haven't seen a photo of a completed one with tubes but it is a consideration. In addition to the possibility of changing sound with tube swaps, tubes look cool. I have seen relatively cheap kit's (not for the Impasse) available for $80 which have 10 or 30 db gain (I didn't see any volume control on that kit, and dare I say it in this group... how do I put this in fine print - tone control.) All of the music source files I have are not produced the same and some are lacking or have too much and are painful to listen to as they exist. I don't have vinyl, and when that day comes around I can add a phono stage.
Maybe switching tubes, or even preamps will allow me to have the missing guitar riffs with their glorious distortion, bass, and pounding drums.
The cost of cabinets for me is what heatsinks cost. I regularly drill and tap metals and have the local supplier cut sheets to size.
Which is going to generate more heat, the F5 T v3, or pair of F4's balanced with preamp providing gain?
I'm surprised at how helpful the community has been. Soldering station arrived yesterday.
Either amp will be great for your situation.
Stereo F5Tv3 (which will almost have to be made monoblock) will produce more heat than balanced monoblock F4.
If you want to run balanced F4, you need a preamp with balanced outputs and about 30db gain. Impasse and Pumpkin is best bet
Impasse
DIY Test Equipment for Audio and Ham Radio Enthusiasts
Much, much more info on this page, but clunky...Index of /Preamplifiers/ImPASSe
Pumpkin
http://dl.dropbox.com/u/20665608/The Pumpkin & Shunty.pdf
http://www.diyaudio.com/forums/pass-labs/119070-pumpkin-preamp-more-boring-making-thread.html
Have sent the tech-diy store an inquiry about availability of parts for the Impasse.
Now for the search for parts for F4! Wow, just looked at your build thread. Really need that much heat sink?
