Can anyone tell me what size fuse to use for my F5 turbo monoblocks with 41V rails? I have 88000uf per rail in the power supply, to the extent that matters.
I was thinking 4amp slo blow?
What is the VA of your transformer? Fuse size is (Transformer VA)/(primary VAC). For North America, primary VAC is 120V.
if proper soft start is in place, calc is simple
VA of xformer/ mains voltage = Fuse rating
go for first bigger standard value, slow blow
Thanks guys. I have 800VA, so 800/120 is 6.666. I will use a 7amp slow blow. Appreciate the advice.
