F5 Or Aleph-M Powered by DC-DC (audio degrades ?)
Ive built a F5 and that went well im currently building an F5turbo v2
Next im going to build another F5 to be powered from 12volt battery biased low, or Perhaps an Aleph Mini which is only a 10watt amp.
So I was wondering about DC-DC converters as ill need a +/- rail from a 12battery. +/- 24v for the F5.
I have a question, In what way would you say does having a converted power supply like this make on the audio ?
I already have as my main amplifier a Jean Hiraga 20w amplifier running from 12batt successfully using DC-DC converter i think you call it.
Cheers
