Well I decided to replace my 200ohm gain resistors on my f5 with 2x200, basically go back to stock.
I pull the boards, add another set of 200ohm resistors on top of the existing, put in new sil-pads, set the pots to 0 and fire it up. Seems good, 0V bias then one of the thermistors on a mosfet catches on fire. Burns up completely.
No resistors burned, Mosfets aren't grounded on the heatsink. What happened? Thermistor accidently touching something it shouldn't? Where to start?
check them all , replace what's needed, case solved
with so low number of parts , there is no use of playin' Poarot , if you already don't remember what was the cause
I know for F5s caught in smoke , when - due to overtemp (sissy htsnks) mosfet goes oped G-D , and that's causing adjacent NTC go puff
in your case ........ dunno
.... set the pots to 0 and fire it up.
hopefully not turned in the wrong direction
personally I never tweak or experiment with amps that work fine
when people ask, did your try this or that cap, etc etc
I say, no why should I, it works fine as is
Yes, I should have left well enough alone.
So, what's the odds that the mosfets and jfets are dead? Bias was 0V, I double checked.
I am going to order new thermistors and pads.
pardon my ignorance- but in putting your gain resistors "back to stock" - is your method of adding in 200ohm resistors - is it in parallel and thus ending up with 100 ohms? which is the "gain" resistor in your case ? -what impedence are you seeking?
And build a lamp checker 🙂
Biasing up Class A with a "lamp checker" ? Are we checking for dim bulbs ?
Well, it was an amp that was up and running good. Guess I could have used a bulb tester.
I had 200ohm resistors on R5-R8 which I had read will increase gain by 6db. Since I am using a preamp now I decided I didn't need the extra gain so I added another set of 200ohm resistors in parrallel to the existing 200ohm to make 100ohm, the stock value.
Since I have to put in new mosfets most likely I'll just put in the proper 100 ohm resistors. Although I don't think that was the problem.
All I have on hand for mosfets is IRFs, I had fairchilds in the amp.
So, if a mosfet grounds with the heatsink is it likely the mosfet is fried? That's my best guess as to what happened.
just pull them out of circ , and check (with usual mosfet test setup)
no need to dismantle them , just desolder one leg of S and G resistors
of course - check their isolation from htsnk , prior to everything else
Good info, thanks Zen.
Anything else I should consider? So, what exactly happens when the mosfet is not isolated? It's dumps V+ to ground? Is there potential for jfet/transistor damage when this happens as well? Nothing was hot after tis happened (except the thermistors) and all resistors look good.
Not biasing. Smoke testing after a component change... 🙂
You cannot bias up a ClassA amp while powered up via a bulb tester.Biasing up Class A with a "lamp checker" ? Are we checking for dim bulbs ?
Even ClassAB amplifiers should not be biased up via a bulb tester.
Yes. Always use the bulb tester after EVERY modification, no matter how simple the mod appears.Not biasing. Smoke testing after a component change... 🙂
yes. class A is not possible. class A/B will can be done. at low bias🙂
No............. class A/B will can be done. at low bias🙂
The bulb increases the source impedance and the result is that the amplifier under test runs on a lower voltage than normal.
If the bias is turned from OFF to a little the voltage drops even more. This results in a false bias voltage.
If the bias is turned up to optimal ClassAB then the voltage will drop a lot and the amp could end up being biased when the rails are at 50% to 80% of "normal" supply voltage.
DO NOT try to bias any amplifier via the bulb tester.
Use the bulb tester to check for errors.
The majority of amplifiers increase bias as supply voltage rises, Some a very little, some so much they will overheat to the point of blowing up.
Well, the saga continues.
I replaced the gain resistors w/100ohm, installed new IRF mosfets and thermistors. Powered it up, no smoke, no fire.
But it won't bias up. P2 has no effect. DC offset is about -1V. Adjusting P1 brings the bias up w/little effect on offset.
I think the Jfets are also burned. That seem like a good diagnosis?
I guess I will order new ones.
So, I had Fairchild mosfets in the amp. I just replaced them w/IRFs. Since I have to order JFETs from spencer I could order some 2SK1530-Y/2sJ201-Y Mosfets too and put them in.
Any mods needed (resistors values, etc.) to install 2SK1530-Y/2sJ201-Y? I hear the toshibas are the prefered mosfet for the F5.
seems so
but might be you would still be happy with the IRF 😛
- F5 mosfet thermistors on fire
