The component numbers/labels have been changed to match the F5 schematics in the F5 turbo article. Except for the P3, component values are the same.
Change to F5 schematics from F5 Turbo article
- Minor diagram change in NTC and limiter sections
- P3 added to adjust N/P variations to reduce distortion
- Relabelling of resistors to match F5 turbo schematics
Layout changes
- JFETs moved further away from current traces
- Hole for OUT moved to other edge of board to make it prettier and increase symmetry
- Middel mounting roles removed
Layout changes
