I know this forum is a DIY one, but I have not seen too many posts on factory built units. A few impressions on my new F4 amplifier:
Well, it got shipped via USPS Priority from California to San Juan, PR in only 3 days . How is that for our postal service.
It is being used to drive a pair of Reference 3aMM DCapo's speakers, and itself driven by a Supratek Chardonnay preamplifier, which is a perfect combination because the Supratek is a very high gain preamplifier. Digital chores are taken care by 47 Labs electronics.
After less than 1 hour of first turning it on, (it really gets hot) the amplifier was producing a very detailed and sweet sound. I checked with Mark about break-in time but he mentioned the F4, according to Nelson, does not really need break-in time. Last night, however, after 30 hours of use I am sure I heard a definitive improvement, i.e., sweeter and smoother.
The inner detail this amplifier produces is amazing and what I like the most, is that one can hear everything there is in the mix at much lower volume levels than with my previous amplifier (Plinius P8, yes I know an overkill)
You understand that the amplifier is burned in and re-adjusted over
a several day period. What people generally experience is the
performance over the first couple of warm-up hours.
In any case, if you're happy, then I'm happy. 😎
The F4 does not need any magical hands, just build it yourself..... If you have the preamp to drive it fully into your chosen speakers, its simply a whopper..... I havent heard anything yet to match it...
Steenoe,
Is there any chance you have the F4 schematic handly?
Oh!! I like fly fishing too.
Albert
Albert
Steenoe,
I built a pair and am fat dumb and happy with, however lacking the equipment , knowledge, and resources to swap components to achieve the optimal balance. I would be curious how our concoctions would sound next to a first watt product.
Bill
Bill
Hi Bill..
You are putting out an interesting question, indeed. I dont think that the factory made units sound better than the DIY ones, generally! Ofcourse it all depends on build-quality... If you skimp too much, the amp won't sound as good as it could. But: The average DIY'er doesn't need to care about a few dollars added cost, so if you build an extra fine PSU, for example, the amp might sound better than the original!! Ofcourse its nice to own a genuine and original product, but the sound of it will probably not be better than your homemade effort...
It could be interesting to compare the Steenoe F4 to the Lykke F4.
Such a comparison should give a hint.
Magura 🙂
Magura 🙂
- F4 - Factory Built- First impressions
