F2,J2,F3,F5 amps and driver layout
Here is a small /simple question - one about taste.
I'd be interested to hear what amps configuration some of you would think of. Here is the matter : four amps, F2, J2, F3, F5
A four way loudspeaker (yes i know, best would be to have one unique driver, simple set up and elegant design as the FW are), crossover frequency
dc - 630hz low
630hz - 1250hz low medium
1250hz - 6300hz high med
6300hz - tweeter
which amps would you assign to what frequency ? Just matter of curiosity
Best
Bottom end
That is what I'm trying to decide :
- Use the F5 for woofer, with more damping
- use the F2 for high, but the F5 with its wide high range has a argument. I only notice the F2 has less noise than the F5 (20uV vs 60uV) and with tweeter with more than 100db spl and not such a big listening room... But I need to listen more, especially with cords instruments with lots of harmonic... let's see, or rather let's hear....😎
I'll probably settle for the J2 in the low medium and the F3 in the high medium
thanks anyway - for your comments and your amps
