In the past, I have built my preamps using +/- 15v rails coming from a CUI PQP3-D12-D15-D dc-dc converter, fed by a suitably large 12v linear supply. I use the recommended external components for ripple reduction and EM emissions. It's sufficiently quiet, and has worked well for me.
However, I have a new project where I will be using a lot of components, some of which are power-hungry. So I need more juice.
I know it's expensive, but I was looking at a Mean Well DKE10A-15 dc-dc converter. However, the datasheet includes absolutely no reference to external components. It does say that EMC circuitry is built-in, and that it has a 60mV ripple max. But there's no equivalent circuit diagram, either.
So is this a truly "black box" solution? I just need the converter device and no other components? Or should I still bypass it with electrolytics and such? What about a ceramic cap from -v in to gnd out? Again, this may be included already but I have no way of knowing.
EMI depends upon circuit topology. Buck related has low EMI at their outputs but large in the input. Boost is exacly viceversa. The best option is a SEPIC + Cuk IMO.
I mean, the device I was referencing is supposedly FCC part 15 class a compliant, and the datasheet says "built in EMI filter". But it doesn't say anything about what that filter may be, or really what is included on the chip. Which makes me wonder whether any external components are needed at all. I can't imagine a converter not needing electrolytics after it at least, but I could be wrong.
In such a case, best are MLCC. Or tantalum. Inductors, depend on frecuency and DCR. If frequency is high, a VK200 choke may do the job.
All of their ~10,000 products are self-contained, so just use within the electrical specs.
Some of them specify the output noise with a certain amount of external load capacitance, like 10uF.
Thanks! That's kind of what I was thinking. Probably wouldn't hurt if I add a couple of electrolytics afterwards (to ground) then? I tend to have some 100uF's laying around.All of their ~10,000 products are self-contained, so just use within the electrical specs.
I would add them closer to the circuit being powered. Should have low ESR.
Personally I use a further noise filter after the converter as well.
But here is the horse's mouth, and he will answer any questions you might have.
He has actual technical knowledge of the Meanwell products, a rarity these days.
Zachary Potter
Electronic Engineer|VAC
T: 510-683-8886 ext.216 or 816-601-4934
MEAN WELL USA, INC.
zachary.potter@meanwellusa.com
Zachary Potter
MEAN WELL USA, INC.
- Analog Line Level
- External components needed for new dc-dc converter
